Thread: cuix file
    2009-11
    Raleigh, NC
    737
    Default cuix file
    I have a customized workspace in my "main customization file (c3d.cuix)". How can I copy that cuix file to another station?
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: cuix file
    Windows Explorer....?
    2009-11
    Raleigh, NC
    737
    Windows Vista
    2005-07
    13
    I don't know where windows vista keeps user files, they seem to have been all shuffled around in that version. However you can save a copy to a location of your choosing using the CUI dialog.
    1. type CUI at the command prompt while in Civil 3D
    2. Select the transfer tab
    3. Drag whatever you want to move from the Left window to the Right window
    4. Using the pull down menu about the right window, select save as...
    5. Move the cuix file that you saved to the new machine
    On the new machine...
    6. type CUI at the command prompt while in Civil 3D
    7. Select the transfer tab
    8. Using the pull-down above the Right window, select open
    9. Browse to and select the cuix you copied to the new machine
    10. Drag whatever you want to move from the Right window to the Left window
    11. Hit apply then OK, and your done.
  1. 2015: Migrating 2014 CUIx File
    By tim_newsome in forum AutoCAD CUI Menus
    Last Post: 2014-11-24, 07:42 AM
  2. Compiling .cuix icons into .dll file...
    By FWSchreck in forum AutoCAD CUI Menus
    Last Post: 2011-06-22, 04:56 PM
  3. Can Transfer be used with a Partial CUIx File?
    By Tom Beauford in forum AutoCAD CUI Menus
    Last Post: 2010-03-04, 09:49 PM
  4. Missing pdfic.cuix pdfmacad.cuix
    By kathleen.143968 in forum AutoCAD CUI Menus
    Last Post: 2010-02-01, 10:51 PM
  5. is it possible to convert a cuix file to a cui?
    By unjust in forum AutoCAD General
    Last Post: 2009-05-12, 01:47 PM
