Results 1 to 7 of 7
Thread: Project Browser/ Properties windows maximized
    2007-05
    107
    Default Project Browser/ Properties windows maximized
    I have a really irritating problem.
    When I have the project browser or the properties windows activated they are both maximized (one at a time) so they take over the entire work area. Is there anyway to control the size of the two windows so I do not need to constantly turn them on and off to open different views or use the properties windows effectively?
    AUGI Addict cdatechguy's Avatar
    2006-10
    CdA, ID
    1,533
    Default Re: Project Browser/ Properties windows maximized
    I take you only have one monitor?
    Your best bet is not to work maximized then and leave the project browser/properties window docked and plead to IT that you want dual monitors!
    Michael "MP" Patrick
    "I only drink :coffee: until it's acceptable to drink or :whiskey: or :wine:"
    2007-05
    107
    It does not matter if Revit is maximized or not the project browser still fills the entire window. My screen is large enough, so I don't need a second monitor, anyways it would just stretch the project browser over both screens and that would be really irritating.
    AUGI Addict sfaust's Avatar
    2004-01
    Littleton, CO (Denver Metro)
    1,535
    are you saying that the project browser is resizing itself? I've never seen that before nor heard mention of it; have you submitted a support request?
    Steve
    AUGI Addict Jrobker's Avatar
    2005-08
    11,000 feet atop a chute
    1,001
    Quote Originally Posted by sfaust View Post
    Is it resizing itself? Or have they been maximized.
    It sounds like a cruel joke someone played on you.
    In 2011, however you leave the size and position of both the Project browser and properties it will remain that way after a close and reopen.
    Can you not resize them back to normal (drag the corner)?
    JR
    "Keeping my view range hopeful."
    2007-05
    107
    If I try to resize it I resize the entire Revit window the project browser changes as well. There is nothing to grab to adjust the project browser window independently.
    It sounds like I'll need to post a support request.
    2010-06
    I had the same problem, but after a while found this solution, i hope will be usefull to you.
    **make sure your account have administrator rights***
    **close all REVIT running applications***
    STEP1: To reset the ribbon and Quick Access toolbar:
    Rename or delete the UIState.dat file located in the Revit MEP folder under one of the following folders:
    For Windows XP:
    %USERPROFILE%\Local Settings\Application Data\Autodesk\Revit\Autodesk Revit MEP 2011
    For Windows Vista:
    %LOCALAPPDATA%\Autodesk\Revit\Autodesk Revit MEP 2011
    For WIN7:
    %\USERNAME\appData\Local\Autodesk\revit\Autodesk Revit MEP 2011
    STEP 2: To reset your project browser to the default location:
    Using the Windows Registry editor (star/run/regedit), delete the following registry key in
    HKEY_CURRENT_USER\Software\Autodesk\Revit\Autodesk Revit MEP 2011\Components\Panels
    **before deleting make sure to do a system registry backup**
    On the right side panel, right click and choose delete on:
    ElementContextSpecificView
    HostByLinkNavigator
    ProjectBrowser
    PropertiesPalette
    RebarBrowser
    SystemNavigator
    STEP 3: Close the Windows Registry editor and restart REVIT that's it.
    good luck.
  1. 2014: Problem with Browser/Properties windows not docking
    By konetarchitecture in forum Revit Architecture - General
    Last Post: 2017-05-25, 09:50 AM
  2. Open Multiple Project Browser Windows at once
    Last Post: 2015-08-31, 04:18 PM
  3. 2014: Stacking Properties and Project Browser
    By vanderloo5 in forum Revit Architecture - General
    Last Post: 2015-06-23, 11:38 PM
  4. Locking Project Browser and Properties Box
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2014-11-04, 03:54 PM
  5. Load windows in maximized mode
    By robert.1.hall72202 in forum Software
    Last Post: 2006-04-12, 09:33 PM
