Thread: Verification fails: "linear load has not been applied to a panel"
    2010-01
    144
    Angry Verification fails: "linear load has not been applied to a panel"
    Hi,
    When I define "linear 2p" surface load analysis verification fails saying the linear load has not been applied to a panel.
    Then how can I make that load to be applied to the panel?
    2010-01
    144
    Default Re: Verification fails: "linear load has not been applied to a panel"
    Would somebody tell me how he or she uses Linear Load? I could not figure it out. It just is not applied to panel..
    2010-03
    69
    Quote Originally Posted by smm.144 View Post
    Hi,
    attach the model please
    2010-03
    56
    I guess you can not apply linear load to cladding. Only uniform surface load can be applied to cladding by using Loads>Special loads>Bars Loads from 3D Objects... menu.
    2008-06
    4
    Hi
    Just tried quick mock up as a shell design and applied the 2p load extreme mid points and all seemed to work ok.
    Can you attach the model or give a description so it can copied?
  1. Panel schedule problem. "Load name" not changing. Urgent!
    By mit81 in forum Revit MEP - General
    Last Post: 2012-11-19, 02:22 PM
  2. Spectral Analysis / Different Load Cases Participating to "Load Mass Conversion"
    By ichandrinos106880 in forum Robot Structural Analysis
    Last Post: 2012-08-02, 01:56 PM
  3. Wall opening fails, "phase setting" blamed.
    By BillB_UH92 in forum Revit Architecture - General
    Last Post: 2011-11-15, 03:13 PM
  4. 2009 Cvl 3D, ??? Load "STP" or "SHX" Files
    By d.lair.doubler in forum AutoCAD Civil 3D - General
    Last Post: 2010-09-10, 08:48 PM
