Yes you are right
It seems that is imposible to calculate Ix for compozite sections in Section Definition Module in Robot
Yes you are right
Hope that a member of the technical support from Autodesk will give an answer. This problem exist since 19 version of Robot Millennium.
Thank you!
P.S. I will bump this thread so that it will remain on top until someone will give an official answer. Thanks for understanding.
This forum is official. but it seems there are not many autodesk specialist to help users in RSA forum, if there is anyone at all. Revit forum is much better. There are many Autodesk specialists there to help you with your problems about Revit. But here only users help each other.. We are so lonely here...
The Robot user community isn't that well supported by autodesk. At least, if autodesk would give on the installation description a link to this web forum, the RSA users that would use this forum will increase, so that more experienced RSA users will share their knowledge.
Hi, Torsional moments (Ix) are calculated for non-composite sections only, at present.
Pawel Piechnik
Autodesk, Structural Analysis Product Manager
