Thread: GPS Position
    2006-03
    Alberton, Gauteng, South Africa
    164
    Default GPS Position
    It it possible to have a parameter/label on the title sheet that can get the GPS position from the position set in the locations dialog box?
    2006-08
    636
    Default Re: GPS Position
    interesting question, is it means to read values of Revit's survey point or shared coordinate system? don't know if it can be done w/o using API, in fact you can get values of shared coordinate system by using API.
    2006-03
    164
    Dont really know how the API works, so wont be able to use it that way
    2004-06
    Memphis TN area
    7,048
    It wouldn't have anything to do with the project and survey points and coordinate systems. I think the OP wants something that strictly reads the GPS lat/lon coordinates shown under Manage > Location.
    2006-03
    164
    Thats correct
  1. Text position in the DB
    By chbouthot in forum Dynamic Blocks - Technical
    Last Post: 2011-05-20, 01:43 AM
  2. 2011: position des caméras
    By izaline in forum Revit Architecture - General
    Last Post: 2011-03-31, 06:15 AM
  3. Can't rotate into that position.
    By zbrown in forum Revit MEP - Families
    Last Post: 2010-09-10, 05:39 PM
  4. Dashboard Position
    By DBill2508 in forum AutoCAD CUI Menus
    Last Post: 2007-11-02, 11:44 PM
