Hi guys,
I'm confused.
I'm using AUTOCAD 2010 and I'm facing on data extraction, there are a lot of way.
My scope of work will be to extract attributes from several equal blocks modify it and import again in the drawing.
I need to modify in a terminal strip each terminal number which is on of the blocks attributes.
So if I have 5 equal blocks in the drawing, and I use express tools I'll receive 5 HANDLE NUMBER and of course all the other attributes.
But I'm not able to match th handle with each blocks.
So I'm trying to use a template file with the blocks coordinate, my be more simple matching the blocks with handle, because all blocks are placed always in a consecutive x or y coordinates.
But in this case I have some problems to create a template file even if it's a simple txt file !
somebody could help me ?
If I use express tools it's work fine, but if I have sever
