Thread: palette problems
    2015-09
    8
    Default palette problems
    Can't drag a custom command onto a tool palette or onto a toolbar. Any ideas?
    2007-11
    Dallas, TX - USA
    352
    Default Re: palette problems
    Quote Originally Posted by rgravelle View Post
    Are your Tool Palettes running on a network location that is locked via I.T. permissions? Are you running an Enterprise CUI? For testing purposes can you drag/drop a block onto any Tool Palette?
    2015-09
    8
    My Tool Palettes are not running on a network location and I am not running an Enterprise CUI. I am able to drag blocks onto my tool palette, but not commands. When I "grab" a command from the CUI Command List pane, it will allow me to "float" to the palette that I would like to place the command on, but the circle-slash remains.
    I should also mention that I am running AutoCAD MEP 2011 but this problem only occurs when I have AutoCAD set as my current profile. When I have AutoCAD MEP set as my current profile, I am able to drag a custom command onto my tool palette just fine. We do a lot of design in 2-D and some design in 3-D and I would like to be able to have both profiles customized the way that I like so that I can move back and forth between profiles depending on the job.
    I did not have this problem with AutoCAD MEP 2010.
    2007-11
    Dallas, TX - USA
    352
    I haven't installed MEP 2011 yet so I wouldn't be able to test myself. Sorry.
  1. 2013: More Tool Palette Problems
    By Borgster in forum AutoCAD Customization
    Last Post: 2014-04-02, 10:24 PM
  2. Problems with Properties Palette
    By richardronan in forum AutoCAD General
    Last Post: 2013-08-29, 04:33 PM
  3. Tool Palette Problems
    Last Post: 2011-03-04, 05:27 PM
  4. Tool Palette Problems
    By jshinn.234181 in forum AutoCAD General
    Last Post: 2010-10-21, 04:38 PM
  5. Tool Palette Problems
    By Renagadex in forum ACA General
    Last Post: 2008-08-29, 08:50 PM
