All my Revit 2011 software crashes when creating/changing materials' Render Appearance. Found an error message in the ArchVision log file.
"BEGIN 5872 Mon Jun 07 19:44:36 2010 "RPC API" The RPC API is contacting the RPC ACM.
LOG 5872 Mon Jun 07 19:44:36 2010 "RPC API" revoke licenses
WARNING 5872 Mon Jun 07 19:44:37 2010 "RPC Content Client" Unable to connect to the ArchVision Content Manager at the following address:
127.0.0.1:14931
Make sure that your RPC Content Configuration contains
the correct address for your ArchVision Content Manager.
You may need to check with your office administrator
to obtain the correct information, or you can use the Scan
feature to locate the ArchVision Content Manager.
LOG 5872 Mon Jun 07 19:44:37 2010 "ArchVision Content Client" connection error == 10061
LOG 5872 Mon Jun 07 19:44:37 2010 "RPC API" revoke licenses
BEGIN 5872 Mon Jun 07 19:44:37 2010 "RPC API" RPC API scanning local paths....
END 5872 Mon Jun 07 19:44:37 2010 "RPC API" RPC API done scanning local paths.
END 5872 Mon Jun 07 19:44:37 2010 "RPC API" The RPC API is done contacting the RPC ACM.
It seems that the RCP API cannot contact the RPC ACM, which makes the program crash.
All the settings in the Option dialog seem to be normal.
Haven't found a solution so far.
