Results 1 to 10 of 20
Thread: EROR IN IMPORT HATCH
    2008-06
    Viet Nam
    52
    Default EROR IN IMPORT HATCH
    THIS IS MY EROR (PIC). WHAT HAPPENED WITH REVIT ?
    AUGI Addict DaveP's Avatar
    2002-12
    St Paul, MN
    1,569
    Default Re: EROR IN IMPORT HATCH
    What does your Revit.pat file look like?
    From the looks of that message, I'd guess your .pat file is empty.
    2008-06
    Viet Nam
    52
    Quote Originally Posted by DaveP View Post
    MY REVIT IS REVIT 2011
    I IMPORT IT FROM acad.pat in AUTOCAD 2007, AND HERE IS SOME FILES I TRIED. IF YOU HAVE WORKING FILE, PLEASE UP IT FOR ME. THANKS
    2002-12
    St Paul, MN
    1,569
    You can't just import a .pat file directly from AutoCAD.
    Although they are ALMOST exactly the same, there are slight differences.
    The Revit file needs to have an additional line:
    ;%TYPE=DRAFTING
    or
    ;%TYPE=MODEL
    included in the description.
    Again, I say - Take a look at your Revit.pat file.
    And, no this did not change in 2011, it's always been that way.
    2008-06
    Viet Nam
    52
    ;%TYPE=DRAFTING
    or
    ;%TYPE=MODEL
    i don't know how to add that line to revit file
    here is my revit.pat file
    All AUGI, all the time gwnelson's Avatar
    2003-04
    Westchester County, NY, USA
    612
    pat is a text (txt) file. You need to open it (them) & add the "Model" and "Drafting" types as shown to one of each (save one as Model, one as Drafting). You can root around among your Rvt pat files to see the typical format.
    2008-06
    Viet Nam
    52
    Quote Originally Posted by gwnelson View Post
    sorry, i don't understand the way you show, can you explain about it more clearly
    2002-12
    St Paul, MN
    1,569
    Do you know how to use Notepad?
    Open one of the .pat files you uploaded in NotePad
    Then open your Revit.pat file in Notepad
    Look at them side by side and compare the differences.
    Here's your BW.PAT
    *bw,Basket weave brick pattern
    0, 0,0, 0,8
    0, 0,4, 8,8, -8,8
    90, 0,0, 0,8
    90, 4,0, 8,8, 8,-8
    and here's a Revit pattern
    *Triangles, Triangular grid
    ;%TYPE=DRAFTING
    0, 0, 0, 0, 0.15
    60, 0, 0, 0, 0.15
    120, 0, 0, 0, 0.15
    You'll just have to figure it out from there.
    If you had opened your Revit.pat file, you'd have seen a great big description explaining how to create a pattern.
    Sorry, we can show you how, but we're not going to do it for you.
    2008-10
    266
    what you need to do, is open of the CAD .pat files, in notepad, add the descriptor, for whether it is a model or drafting pattern, save the file, then you can load into Revit, for a working hatch pattern.
    2008-06
    Viet Nam
    52
    Here's your BW.PAT
    0, 0,0, 0,8
    0, 0,4, 8,8, -8,8
    90, 0,0, 0,8
    90, 4,0, 8,8, 8,-8
    ;%TYPE=DRAFTING
    0, 0, 0, 0, 0.15
    60, 0, 0, 0, 0.15
    120, 0, 0, 0, 0.15
    i've add ";% TYPE=DRAFTING" in BW.pat.
    before i add, revit show eror in line 2, after i added, revit show eror in line 3, so i don't know how to fix
  1. 2011: Import Acad Hatch Patterns and assign to materials
    By myoula882294 in forum Inventor - General
    Last Post: 2011-03-14, 05:14 PM
  2. Eror in Loading Structure Family
    By thinhphamkts in forum Revit Architecture - General
    Last Post: 2010-05-24, 03:25 PM
  3. Import hatch patterns into 2009
    By hrchandleur in forum CAD Management - General
    Last Post: 2008-06-19, 10:16 PM
  4. Import AutoCAD Hatch Patterns
    By Mike Y in forum Inventor - General
    Last Post: 2008-06-05, 06:51 PM
  5. Trial version - unable to create or import new hatch styles
    By rkitect in forum Impression - General
    Last Post: 2007-06-12, 02:16 AM
