Thread: Coonstrain Matters
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    Default Coonstrain Matters
    Hi ALL,
    I currently have 2 parts (a disc & a lid) in assembly.
    The problem is that I cannot constrain two faces (showing one in red & another is pink).
    Please find the attached files in v2010.
    Your helps are much appreciated.
    2006-09
    133
    Default Re: Coonstrain Matters
    In what way to you want them constrained?
    2006-04
    1,160
    Quote Originally Posted by mflayler View Post
    Simply the lid covers the disc.
    Don't worry if the surface angles are different.
    Thanks.
    2006-09
    133
    I did this two different ways.
    Quick and Dirty:
    Make both parts into a Contact Set state
    Turn on Contact Solver
    Push them together
    Get Distance offset for CPs
    Use that value for Mate offset for CPs
    More precise:
    Created Surface in one part to represent where it would contact the other part. Constrained surfaces to edge of disc.
    2006-04
    1,160
    Quick and Dirty:
    Push them together
    More precise:
    Yes, I tried what you mentioned & I prefer the second method.
    Thank you very much.
  1. LCD Monitors: What matters for architects?
    By rat69 in forum Hardware
    Last Post: 2021-07-27, 02:20 PM
  2. Family matters
    By edenreagh2 in forum Revit - Student Support
    Last Post: 2010-11-15, 11:32 PM
  3. Every Step Matters - Working with Revit Content built wrong
    By 3dway in forum Revit Architecture - General
    Last Post: 2008-12-09, 01:36 PM
