Thread: Navis Animation
    2010-06
    3
    Question Animating a crane
    Dear Sir
    If we to do 3d-Animation in Navisworks is it possible & I want to Review the 3D-Model in Navis,for example if it is a crane i want to show it navis in a animation in a such a way that it is moving really in the model,how carry out with this task.Please explain me .
    2010-06
    3
    Question Re: Navis Animation
    Can u expalain me how to carry out with the Timeliner & animation option in NavisReview-2009 please.If u got any procedure can u mail to my personal id shiva_8846@yahoo.com.
    2010-06
    3
    Dear Sir
    I want to know how we carry out the option Animation & Timeliner in NavisReview-2009 in detail & also i required to do 3d-Animation in Navisworks & for example if it is a crane i want to show it navis in a animation in a such a way that it is moving really in the model,how carry out with this task.Please explain me & help me out regarding this.
    2004-06
    4
    Default Re: Navis Animation
    You need to use the Scripter in Navisworks to animate objects, this works by adding "key frames" just like most other animation software. Select the object you want to animate, add a starting keyframe then move the object to its next point and add another keyframe, etc. Navisworks will interpolate (fill in) the rest path automatically.
    2006-05
    Portland, ME
    198
    Quote Originally Posted by mtcdesign View Post
    You need to use the Scripter in Navisworks to animate objects.
    You need to use the Animator module and follow the steps that mtcdesign mentioned. There is a brief chapter on this process in the user manual. This is located in the install directory or you can access a web version of it here:
    http://www.scribd.com/doc/22649445/A...ge-2009-Manual
    Cheers
  1. 2014: navis 14
    By sjsl in forum NavisWorks - General
    Last Post: 2014-01-27, 08:37 PM
  2. 2013 new to navis - animation help please
    By urbanista in forum NavisWorks - General
    Last Post: 2013-04-04, 03:19 PM
  3. Animation used for Navis 2011 Promotion
    By Maddy in forum NavisWorks - General
    Last Post: 2010-11-23, 03:41 PM
  4. Navis 5 nwd vs. Navis 2009 nwd
    By diesellam in forum NavisWorks - General
    Last Post: 2009-03-03, 07:31 PM
