Thread: Coordinate System not in Oracle Connection
    2007-11
    9
    Default Coordinate System not in Oracle Connection
    Hello,
    Why would a coordinate system show up in an arcsde connection but not in an Oracle FDO connection?
    Direct oracle connection is twenty times quicker than an ArcSDE but it wont read the coord sys.
    Please see attachments
    TN/KY Area
    1,640
    Default Re: Coordinate System not in Oracle Connection
    I would take a guess and say because the middle ware of ArcSDE is where that definition of the coordinate system is stored. You should be able to double click on the UNKOWN and select the one you know it is in for the oracle connections.
  1. Replies: 0
    Last Post: 2011-01-25, 05:59 AM
  2. Problem Autocad Map 3D Oracle connection
    By balkanay in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2010-08-31, 07:24 PM
  3. Oracle Connection Error
    By freda.kuhl.ctr in forum AutoCAD Map 3D - General
    Last Post: 2009-08-16, 01:11 PM
  4. Need HowTo of creation connection AutoCAD - Oracle
    By mich569 in forum AutoCAD Map 3D - General
    Last Post: 2009-01-24, 03:11 PM
  5. Coordinate System
    By mccurdyks in forum Revit Architecture - General
    Last Post: 2006-06-21, 05:05 PM
