Hello,
in AutoCAD 2D we always used different line types to indicate the level in with the pipes runs, e.g. solid when near floor level, dashed when below floor level, dash-dot-dash when visible on high level.
Although the pipes are drawn on the right level/offset in Revit, from a floor plan drawing it is then hard to identify, where the pipe runs. The contractors typically don't want the 3D model, only 2D plans.
Is there a way to show the pipes in the different line styles dependent of the level they run? If I set the bottom view range to e.g. 0.0 and the view depth to e.g. -500, the pipe appears thinner. Is it possible to change this so that the pipe appears also dashed?
How is this done is other practices? Do you provide notes with the level?
Regards
Volker
