I'm creating a model for the contractor that wants to experiment with material extraction right out to a Revit model. So the output would be fully paperless. I'm testing to see if you can go as far as modeling each brick. That way you can count the amount of bricks. Since there are 4 sets of random bricks placed in the wall you can controll where each brick is placed.
For this sample, I modeled the one type of brick in a curtain panel pattern based family and insert it into a mass family. As I expected, the model gets very heavy.
So my question is, how do you deal with this performance issue?
a. model a whole set of bricks as one curtain panel family instead of each individual brick
b. model each brick as a generic family and stack them manually in the project. (less contraints = lighter model.
c. model a whole set of bricks in autocad (see second attachment, SHoP architects sample) and import itas a 3d dwg or family in Revit.
Also, does anyone know an API code that lets you randomize panels in a curtain wall?
