Does the frame generator (located at add-ins) works fine for everybody?
For me all models stuck at 47% while generating the geometry.
First try to switch off calculation options before generation. If it doesn't help the best solution is to reinstall software. Probably something went wrong during installation.
Thank you Tomasz,
switching off calculation options didn't work. I 'll try reinstall ARSA.
If after reinstallation problem will still exist then contact Autodesk support. This Frame Generator feature should work. It works on my machine.
Reinstallation didn't work either. I'll place a support request.
Thanks anyway.
What design codes for steel/aluminum structures do you use?
We suspect steel labels creation problem.
I use EC3,
i've tried today with a windows 7 pc and worked fine. The problem remains with windows xp.I gues that something is wrong with my pc than ARSA since every bug that encountered until today was appearing in both my workstations.
Thanks
Frame generator (RSA2011-sp3) creates a new beam "thing" called "superbar" which turns the two gable roofbeams into one. the 2 gable roof beams still exist under this "superbar"
what is this "superbar" which section after the optimization is IPE 700000+ ?
