Ewen
Hi Alex.
To belatedly answer your question, in case someone else wants to know, it it a Windows 7 option (you didn't say which OS you are using). From memory, I think it was on the main properties page, right at the bottom.
I'm not sure that installing MSIs from a network location is particularly reliable - you're usually better off copying them locally & running from there.
If you're referencing the DLLs from the AutoCAD SDKs you will find that the project will build regardless of whether you have AutoCAD on the machine or not. Obviously it won't run if there's no AutoCAD to NETLOAD your DLL into.
