Hi, I have attached a picture of some columns with beams framing into them. The beams are offset from the centre of the column. How does one reconcile the analytical model so that both beams tie into the column?
Thanks once again Tomasz! Hopefully Robot will still recognize the correct distances (span of slabs supported by the beams) of the physical model.
You can try and use wall (shell elements) instead of bar element for that column.
Yes that is a possibility, that I might have to use.
The "analytical adjust" places the beam diagonally between the 2 points, and the beams are also generated diagonally in Robot.
I am also wondering if I can place the beams to coincide with the column analytical object and then define (horizontal) bar offsets in Robot.
I have attached the Revit analytical and the Robot 3D image
