Thread: Equivalent of ETABS "end offsets" in Robot
    2010-04
    52
    Default Equivalent of ETABS "end offsets" in Robot
    ETABS has a feature called "end offsets" which can be used to model the finite cross sectional dimensions of structural members at beam column junctions. That is even though the analytical model might show a span of say "x" between supports, the clear span would be "x-a". With deep supporting members, say a structural wall in the same plane as a supported beam, the effect of this reduction in span between the analytical and physical model could be quite significant. I was wondering whether Robot had a similar feature?
    2010-01
    144
    Default Re: Equivalent of ETABS "end offsets" in Robot
    I don't think Robot has similar feauture (End Offsets in Etabs)...
    2010-01
    Greece
    47
    From Geometry->Additional attributes->Offsets you can achieve what you are looking for. This function is identical with the one of ETABS.
    2010-04
    52
    ETABS has 2 features, "frame end length offsets" and "frame joint offsets". What you are describing seems to be more related to the latter, where a frame member joins eccentrically into another. I stand to be corrected though
  1. Need single-door equivalent of Revit's "Store Front Double Door"
    By Ralph.143107 in forum Revit Architecture - Families
    Last Post: 2016-05-23, 03:25 PM
  2. [Revit-Robot connection] Missing custom database in "Mapping of elements" window
    By StroocturalEng in forum Robot Structural Analysis
    Last Post: 2012-05-06, 05:36 PM
  3. is there an equivalent of "entnext" in vla
    By Serhan_BAKIR in forum AutoLISP
    Last Post: 2010-04-06, 01:45 PM
  4. Category Parameters (ex "Offsets")
    By jennifer.montgomery in forum Revit MEP - Families
    Last Post: 2007-04-05, 07:43 PM
  5. Is there an "xopen" equivalent?
    By gordon.84736 in forum Revit Architecture - General
    Last Post: 2005-07-01, 01:07 AM
