Results 1 to 6 of 6
Thread: door and window schedules
    2010-06
    49
    Default door and window schedules
    how do you do all the door, window, and light schedules, i forget. its been so long ago that i had to make them
    I could stop if I wanted to eldad's Avatar
    2004-01
    230
    Default Re: door and window schedules
    from your view tab select schedules -->schedules/quantities--> door schedule etc.
    you can also create a legend should you want a graphical representation of doors and windows...
    2004-06
    Memphis TN area
    7,048
    May I suggest going through some tutorials and other Revit documentation? It's good that you participate in these forums, but there is lots of useful information readily available from Autodesk and other sources - such as these video tutorials and user documentation here:
    http://usa.autodesk.com/adsk/servlet...12&id=14996975
    This should help you with most of your basic questions and issues.
    2016-01
    Harrow, UK
    50
    What a pain not to be able to tag windows and doors on Legends. It's such an obvious requirement.
    Look forward to seeing this in Revit 2012 (but have a long wait)
    Pittsburgh, PA USA
    1,906
    You need to search on other threads. Making the legend views "tagable" will actually break other needs for legends. What Autodesk needs to do is provide a second type of legend view that is agable, and that you can adjust instance parameters of object in. It'll take both od these items to make a tagable legend worth while, while preserving the original type of legend as well.
    2004-06
    Memphis TN area
    7,048
    Yeah we also discovered that note block symbols will not populate the note block when placed in a legend. Factory says that's because the legend should be there for making a legend of symbols, not for placing a symbol that refers to a note about something else in the legend.
  1. Live elevation door and window schedules - not static legend views
    Last Post: 2018-08-05, 10:43 PM
  2. Replies: 0
    Last Post: 2013-04-17, 04:46 AM
  3. Door / Window Schedules & Schedule Tags
    By mflure.80520 in forum ACA General
    Last Post: 2005-04-15, 04:55 PM
  4. opening, door & door/window components improvement
    By luc.magnee in forum ACA Wish List
    Last Post: 2004-06-23, 06:49 AM
  5. Window & Door Schedules - graphics
    By trombe in forum Revit Architecture - General
    Last Post: 2004-01-26, 02:59 PM
