Results 1 to 10 of 10
Thread: "Undefined shape" but no missing shape file?
    2008-12
    6
    Default "Undefined shape" but no missing shape file?
    Land Desktop 2007
    One of our computers is giving an "undefined shape ##" error when we try to edit existing text or mtext (one error for each character typed). But, when you hit enter after the errors, the new text does appear, and in the correct font... you just can't see it while typing.
    No errors when you regen or create new text of the the same style, so it seems that the shape file is fine...?
    in the upper right corner
    3,508
    Default Re: "Undefined shape" but no missing shape file?
    Just a thought, does the computer in question maybe NOT have the font being used by the existing text and mtext? Maybe acad is subsituting something and causing an error when editing?
    Check the text style's font to see if matches other machines.
    (like I said, just a guess pulled out of my ... )
    2008-12
    6
    No, the fonts listed are correct.
    I've also just learned that this problem seems to be intermittent- sometimes closing and reopening the drawing makes it stop, sometimes it doesn't. Someone else just told me that they have "occasionally" seen a different computer do it as well, but they didn't know if it was the same drawing. Wish I knew what the pattern was...
    9,805
    Quote Originally Posted by cheshirecatfish View Post
    Land Desktop 2007
    I'll try to explain using an example:
    Let's say the drawing was created on a different machine by a different company. On that machine, they have a font named "simplex.shx", but they have customized the font by adding some characters. Then they created some text with these special characters.
    Now they send you the drawing, and you have "simplex.shx", but it is not the exact same file. So when AutoCAD tries to display the special characters added by the others, it can't and reports "undefined shape..." (each character in a font file can be referred to as a shape).
    Hope that helps.
    3,508
    Hope that helps.
    Thanks RK.. that's kind of where I was headed but couldn't explain myself as well .
    I know that some offices can have a different version of a font with the same name, on different computers.
    2008-12
    6
    Ted and RK, wouldn't the error only occur when attempting to edit those characters that differ between versions of the font file? We get the error for every character we try to type. Could your suggestion cause an intermittent problem like we are seeing?
    Is there a variable related to the display of text that could cause something like this if it were set incorrectly? I ask because we've had issues before with variables getting intermittently reset for no reason we could find.
    9,805
    A) Not sure.
    B) Can you send me the drawing? I'll take a look.
    No, I don't think so.
    2008-12
    6
    Well, here is the file we've had the problem with this morning. I haven't been able to reproduce the error on my computer, or in another drawing... but since it's intermittent to begin with, that doesn't really verify whether or not the problem is computer- or drawing- specific.
    2011-06
    I saved acad block notice: ** Undefined shape 49 .help me. thanks
  1. 2013: What is "shape-edited floors of more than one layer"
    By mike99 in forum Revit Architecture - General
    Last Post: 2013-06-08, 09:59 AM
  2. Prevent "Select shape file" window whenever I open a DWG file
    By dgotto in forum AutoCAD LT - General
    Last Post: 2006-11-14, 05:14 PM
  3. Missing Shape Files / Select Shape File
    By Mac Demer in forum AutoCAD General
    Last Post: 2006-11-05, 01:36 PM
  4. Open drawing file - "Select Shape File" message appears
    By gdgutie in forum AutoCAD General
    Last Post: 2006-02-07, 05:48 PM
  5. Seeking help w/a geometrically "fudged" shape...
    By John K. in forum Revit Architecture - General
    Last Post: 2003-11-26, 08:36 AM
