Hi, once a model has been exported to Robot for analysis, is it possible to update the Robot model with any changes made in Revit to the model?
The connection between Revit and Robot is bbidireccional, any change in one of the aplications could be easely updated to the other.
Could you please explain the procedure to update a Robot model from Revit?
First, you need to use extensions4revit, a add-in from Autodesk that you find in subscription site.
In that add-in you had export options to Robot, later when working in Robot you go to Revit and choose update from Robot
I know you can update a revit model from a robot model. What about in the other direction?
It´s the same, using revit Add-ins, it can be updated to both sides.
The Getting Started Guide describes this pretty clear in the chapter Integration of Autodesk Robot Structural Analysis with Revit Structure.
http://www.autodesk.com/robot-support
