Thread: AutoCAD LT 2010 does not see Civil 3D 2010 objects (surface contours, etc.)
    2008-08
    Default AutoCAD LT 2010 does not see Civil 3D 2010 objects (surface contours, etc.)
    Hi,
    I've created a contour map using Civil 3D 2010 (with some GIS data imported), and now trying to use it in LT 2010, and, of course, none of the 'smart' civil objects are there. The standard proxy graphics message appears directing to check Autodesk web-site for object enablers http://usa.autodesk.com/adsk/servlet...linkID=9240618. LT is not listed. I've tried plain CAD, but it won't work. I'm new to LT. Could anyone advise how to make those objects appear? Thanks.
    2001-12
    Dallas, TX
    229
    Default Re: AutoCAD LT 2010 does not see Civil 3D 2010 objects (surface contours, etc.)
    There is an Object Enabler for LT2011, but not for LT2010 or lower. No fix or workaround for LT2010 exists to get them installed:
    http://usa.autodesk.com/adsk/servlet...linkID=9240818
    ProxyObjects and Proxyshow turned on both seats (Civil first, then resave the file, do the same in LT before opening the file) seems to be the one limited-use option if upgrading to LT2011 is not in the cards.
    2008-08
    Maaan... LT 2011 gotta wait, i'll try the proxy option. Thank you.
  1. AutoCAD 2010 civil?
    By eolivier in forum ACA General
    Last Post: 2010-03-18, 08:29 PM
  2. looking for the aeccxstylewizard for autocad civil 3d 2010
    By KAMINSKYPHIL in forum AutoCAD Civil 3D - General
    Last Post: 2009-09-21, 10:06 PM
  3. CIVIL 3D 2010 OBJECT ENABLER FOR ARCHITECTURE 64BIT 2010
    By yangcheng2008 in forum AutoCAD Civil 3D - Grading
    Last Post: 2009-06-17, 01:34 PM
  4. Surface from Civil 3d contours
    By jmoore.136085 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2008-08-22, 08:22 PM
