Thread: Duct Tag Leader Connection
    2008-12
    San Francisco, CA
    66
    Default Duct Tag Leader Connection
    I would like to modify my duct tag family to give me the option to attach the leader not to the center of duct but to the sidewall.
    Any help is greatly appreciated!
    Neil
    2002-06
    North Central CT
    1,108
    Default Re: Duct Tag Leader Connection
    Select the tag and, in the options bar, change it from ATTACHED END to FREE END. This will allow you to move the end of the leader anywhere you want. Probably not EXACTLY what you're looking for, but it's a solution. Besides, I don't see any way around it automatically attaching to the center of the duct.
    Matt
    2008-12
    San Francisco, CA
    66
    Yes, I thought there use to be the option to attach to duct wall instead of center. Maybe I'm wrong
  1. 2013: Duct branch connection results in single line duct!
    By kevinmurtha in forum Revit MEP - General
    Last Post: 2013-01-29, 01:37 PM
  2. multiple connection point for leader tails when using a multi-leader
    By jschraud228486 in forum AutoCAD Annotation
    Last Post: 2010-06-16, 01:42 AM
  3. Duct Connection Array
    By Hurls in forum Revit MEP - Families
    Last Post: 2010-04-21, 03:47 PM
  4. Room tag leader to box connection problem
    By ROBinHI in forum Revit Architecture - General
    Last Post: 2009-12-14, 11:14 PM
  5. Movable duct connection on AHU plenum - possible?
    By christo4robin in forum Revit MEP - Families
    Last Post: 2009-03-06, 06:39 PM
