Thread: Event Handlers
    2004-08
    50
    Default Event Handlers
    In moving my code up to ACA2010 i have discovered an issue. I have code attached to the document_activate and document_endsave events. These do not fire reliably. If i have more than one vba project loaded, they do not always work. Only one project loaded will always fire them. I am hoping not to need o combine all my projects into one giant file. Is there a trick to this behavior? Has anyone else noticed this? Perhaps something else is wrong altogether.....
    -mjm
    2000-01
    Seattle WA USA
    5,859
    Default Re: Event Handlers
    I've noticed this in 64-bit but can't say I've seen it with 32-bit.
    R. Robert Bell
    Design Technology Manager
    Stantec
  1. Replies: 9
    Last Post: 2014-07-07, 02:40 AM
  2. Event Viewer
    By clarkl in forum AutoCAD Civil 3D - General
    Last Post: 2011-11-04, 03:45 PM
  3. Unregistering Event Handlers (Design Question)
    By tgross.197084 in forum Dot Net API
    Last Post: 2009-09-28, 07:15 PM
  4. Selection Event
    By gdaniels in forum VBA/COM Interop
    Last Post: 2008-04-23, 06:07 PM
