Thread: Shared Parameters in Key Schedule
    2010-05
    6
    Default Shared Parameters in Key Schedule
    I am trying to utilize a key schedule for room types. I wanted to use this to fill in some data in some newly created shared parameters but the parameters are not availible in the key schedule. Anyone know why they would not be availible? or how I could work around this?
    2006-03
    461
    Default Re: Shared Parameters in Key Schedule
    Are the shared parameters assigned to the room category in the project?
    After that, you then have to pick that parameter in your key schedule setup.
    2010-05
    6
    yep the parameters are assigned to the rooms catagory and they are working fine for a normal room schedule but they are not selectable when the "schedule keys" option is checked.
    2005-07
    3,250
    I think this has been a long-standing wishlist of a lot of users. Shared parameters are not available in Schedule Keys. The only solution is to use Project parameters instead.
  1. 2015: Shared Parameters and Door Schedule
    By colnagoboy in forum Revit Architecture - General
    Last Post: 2015-07-10, 03:46 PM
  2. Key Schedule, Room Schedule & Shared Parameters
    By ron.sanpedro in forum Revit Architecture - General
    Last Post: 2012-04-19, 05:35 PM
  3. 2012: Shared parameters in style schedule
    By kafka in forum Revit Architecture - General
    Last Post: 2012-04-19, 11:34 AM
  4. Shared Parameters for Materials & Schedule
    By stuntmonkee in forum Revit Architecture - General
    Last Post: 2008-06-05, 04:04 PM
  5. Shared Parameters in Key Schedule
    By E-Key in forum Revit Architecture - General
    Last Post: 2005-08-22, 03:57 PM
