Thread: Eave Rafter tails
    2006-04
    81
    Default Eave Rafter tails
    I need your help everyone.
    What is the best way to add eave rafter tails to your model. I know most of you sketch it in your sections which is the easiest to do but our office standard is to show the eave design on our ceiling plans (Beams, T&G, etc...) . My current project has foe beams that would attach to the bottom side of my roof but end at the wall....I'm clueless on where to start. Also, the beams will be at 45 degree angle at hip locations (see image).
    I could stop if I wanted to Teresa.Martin's Avatar
    2004-11
    438
    Default Re: Eave Rafter tails
    Use a faced based generic family. You can then stick this on the underside of the roof.
    You will see a faced based family in the template list when you create a new family. You can change its catagory later if you want to schedule it differently.
    Best regards,
    2004-11
    438
    You could also make a custom brace family (structural Framing - Beams and Braces.rft) and use 3d snapping to place. In either case, there will be some custom family creation that you will need to do.
    Best regards,
    2004-05
    Auckland, New Zealand
    341
    Eric
    There was also somewhere on AUGI, this same thing, where someone used a Railing, with a Balustrade Post shaped like the rafter
    2006-04
    81
    thanks, i give those ideas a try.
  1. Creating rafter tails using cut geometry?
    By skyeg3206316 in forum Revit Architecture - General
    Last Post: 2012-08-18, 11:50 PM
  2. Exposed rafter tails during DD's
    Last Post: 2008-07-02, 09:46 PM
  3. Roof style - open rafter tails
    By Jon_ImpactDrafting in forum ACA Wish List
    Last Post: 2007-04-11, 02:23 PM
  4. Roof eaves and rafter tails
    By ctdrafting in forum Revit Architecture - General
    Last Post: 2006-01-24, 06:43 PM
  5. Roof base rafter tails
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2005-09-13, 08:55 PM
