Thread: Blurred and Faded Drawing.
    2010-02
    7
    Default Blurred and Faded Drawing.
    Hi,
    I have this particular drawing when I open it the whole screen turns blur/faded. I tried play around with the Transparency and set to 0 but still the same. I don't know is this because of the drawing itself or need to do some setting issues. Pls advise and TIA.
    2001-05
    Austin, TX USA
    2,201
    Default Re: Blurred and Faded Drawing.
    Is all the line work x-refed in or on a locked layer?
    For x-refs, check out XDWGFADECTL
    For locked layers, check out LAYLOCKFADECTL
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    Cairo - no, not Illinois
    4,852
    that looks like it's a scanned image -- not line work. If so, then the quality has everything to do with the image file, and nothing to do with Acad
    2010-02
    7
    @Glenndp: Thank you for the advised. Yes, some of the layers are xref. I'll will try your suggestions.
    @cadtag: Its is a Acad file and not a scanned image.
    Thanks everyone the problem is solved. Type command xdwgfadectl enter value <0>.
  1. 2012: Screen is faded
    By Borgster in forum AutoCAD General
    Last Post: 2011-12-12, 12:44 PM
  2. 2011: Autocad Drawing Appears Faded
    By tera.a.richards in forum AutoCAD General
    Last Post: 2010-09-01, 03:30 AM
  3. Faded materials
    By katarina.tisma in forum 3ds Max - General
    Last Post: 2008-09-02, 01:50 PM
  4. Blurred Reflections
    By arshiel88 in forum 3ds Max - General
    Last Post: 2007-09-06, 09:59 PM
