Hey guys,
I made a drawing template with all the fields for my TitleBlock and Xref the title block in the template. Now when i use sheet set manager i reference the template and i create the custom properties to match the fields on the TitleBlock. Now it works fine and the fields displays my project number, sheet name, Date, Rev numbers, scale, etc. I can then use the "Insert sheet list option if i right click on the sheet set name to generate all my drawing names, numbers and Revisions. Now i copied a layout tab and it looks exactly the same but is detached from the sheet set and does not update. Does using fields work with multiple layout Tabs? The reason being you can have a drawing with different zones in each tab, rather than multiple drawings. Am i subjected to create a new sheet in order for the Fields to be effective?
