Thread: Tapered Beam Mesh
    2010-06
    5
    Default Tapered Beam Mesh
    Whenever I try to create a FE model for a shell that is supported by a variable height beam (for instance a cantilever) the model generation changes the height of the beam in a non-linear way in accordance to the FE size of the shell.
    For example: for a beam with a starting height of 80 cm and a height at the end of 40 cm, for a given length of 5 meters, if the 1st meter mesh is more dense than the rest, then the height of the beam goes from 80 to 70 cm in this first meter, and from 70 to 40 cm in the rest 4 meters.
    I tried to use standard size meshing but I need to use finer meshing at supports so this problem comes up...
    Any way around it?
    Thank you
    2009-11
    32
    Default Re: Tapered Beam Mesh
    I am not sure how you verify the height of the beam along the bar with tappered section.
    Can you attach a snapshot?
    2010-06
    5
    From the 3d model.... Unless it is simply a visual issue and does not represent the analysis model... though i doubt it... Is there a way to check this out?
  1. Replies: 1
    Last Post: 2010-08-30, 05:46 AM
  2. Tapered beam: Analytical vs physical model
    By smadsen100 in forum Revit Structure - General
    Last Post: 2010-04-16, 07:11 AM
  3. ASD 2010 - Tapered Beam design
    By neiledwigfern in forum AutoCAD Structural Detailing
    Last Post: 2009-06-02, 04:02 AM
  4. Tapered Wide Flange Beam
    By abink in forum Revit Architecture - Families
    Last Post: 2007-06-28, 01:03 PM
  5. Tapered structural beam - how to make it?
    By abink in forum Revit Architecture - General
    Last Post: 2007-02-07, 10:25 PM
