Thread: Unable to open regular AutoCAD 2007 from Mechanical 2007
    2006-10
    53
    Exclamation Unable to open regular AutoCAD 2007 from Mechanical 2007
    We all have Autodesk Mechanical 2007, but most of us use the regular AutoCAD 2007 installed along with it. However, one of my group can not get the regular version of AutoCAD 2007 to open on their machine. I assume there is a setting somewhere that is affecting this, so any of the Mechanical users out there have any ideas as to what it is?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: Unable to open regular AutoCAD 2007 from Mechanical 2007
    It sounds like a profile issue. Does a profile for AutoCAD only exist? You could export a profile from one of the other computers where it works to the computers where it does not. You could then create a shortcut to load AutoCAD Mechanical as AutoCAD by specifying the profile to use with the /p switch.
    0,0,0 The Origin
    8,570
    Look for a profile called <<VANILLA>>, that should do it.
  1. Upgrading from AutoCAD Mechanical 2007 to 2008
    By akamarathonman in forum AutoCAD CUI Menus
    Last Post: 2008-09-04, 12:40 AM
  2. AutoCAD 2007 and 2008 unable to open a DWG file saved in 2004 format
    By Neo_Richard_Blake in forum AutoCAD General
    Last Post: 2007-07-09, 08:50 PM
  3. AutoCAD 2007 – Unable to open DST files
    By Trevor_Smith in forum AutoCAD Sheet Set Manager
    Last Post: 2007-04-24, 05:46 AM
  4. Mechanical AutoCAD 2007 books for beginners
    By boskovbo in forum AutoCAD Mechanical - General
    Last Post: 2007-04-22, 08:11 PM
  5. AutoCAD 2007 - DWG to PDF, Mac user unable to Open/Print PDF's
    By john.113502 in forum AutoCAD Plotting
    Last Post: 2006-06-06, 01:11 AM
