m20roxxers
Create a table of the points in AutoCAD, export them out to excel, then put them in x,y,z rows and save them out as csv files.
if they are far away from the origin I would them them closer note the original poitn of the original then update the co-ordinates in Revit.
I would only do this if you don't want to import the cad files or the cad file is large lots of layers and very messy easier jus to extract your selection of points from cad then trying to carve up the model,contours,drawing.
How it should be working fine with the standard import system in Revit.
What sort of point objects are appearing in cad?
