Thread: Fishbowl Lens
    2007-05
    Cincinnati, OH, USA
    49
    Default Fishbowl Lens
    So I have been working on the same model for coordination for the last few months with no problems. I have not messed with any of the settings in any way, shape or form. Just yesterday when I opened the model everything appears like you are looking through a fishbowl and a sectioning plane seems to be "turned on" about a foot in front of the camera. Has anyone else had these problems. Thanks in advance.
    I could stop if I wanted to Teresa.Martin's Avatar
    2004-11
    438
    Default Re: Fishbowl Lens
    Two things I know of can cause that. One is the avatar being turned on (but invisible or very small as not to be visible). This will change the FOV of the camera. The other thing is the FOV itself. If it gets changed in one view it will stay that way as you navigate. Also, clicking on the view cube and having Fit to view on change selected in the Options dialog box (Application menu>Interface>Viewcube.
    I hope one of these helps!
    Teresa Martin
    Senior Application Specialist, IdeateInc
    Ideate on Youtube! http://www.youtube.com/user/IdeateInc
    Ideate Solutions blogs! http://ideatesolutions.blogspot.com/
    Check out my blog: http://bimnewworld.blogspot.com
    2010-01
    6
    Additionally, the mysterious sectioning tool is most likely your near clipping plane. In large or complex models, the combination of guaranteed framerate and automatic clipping planes can occasionally cause geometry to be sectioned or vanish in an undesirable way. In 2011, go to home tab on the ribbon and click File Options. Change your near clipping plane from the automatic settings to achieve more desirable camera functionality. Also note that things such as transparency can dramatically increase the demand on your graphics, causing the clipping planes to close in on the camera rapidly.
    2007-05
    Cincinnati, OH, USA
    49
    Quote Originally Posted by Teresa.Martin View Post
    Thanks Teresa,
    I clicked on the Viewcube and chose the home option and it took care of my problem.
    Thanks again,
    Chris
    2004-11
    438
    Smile Re: Fishbowl Lens
    Good! I am glad that fixed it. Sometimes things do seem to happen mysteriously in Navisworks
    Teresa Martin
  1. Camera Lens Length Properties
    Last Post: 2015-10-19, 08:44 AM
  2. Navisworks field of view = Camera Lens Focal Length?
    By rsloyer in forum NavisWorks - General
    Last Post: 2010-03-15, 03:48 PM
  3. camera lens-default?
    By cliff collins in forum Revit - Rendering
    Last Post: 2008-10-03, 03:02 PM
  4. Lens Length in 3D Orbit
    By guyayers in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-09-17, 07:56 PM
  5. Camera align view/zoom lens parameter
    By a-mi in forum Revit Architecture - Wish List
    Last Post: 2004-11-02, 02:46 PM
