I'm not finding any helpful information on this topic.
Is is possible to query a custom property of the SSM, provided you know the property name you seek?
I know the SSM file (.DST) is a separate file from the drawings themselves. Does ActiveX provide a means by which to "read" the .DST file properties, as it is technically an opened file within AutoCAD?
The SSM file name doesn't appear in this list:
I'm automating some of our "revision" processes, and was on a role until I encountered this issue. I'm hoping it's more of a speedbump, than a roadblock.Code:(vlax-for each (vla-get-documents (vlax-get-acad-object)) (setq docList (cons (vla-get-name each) docList)))
If anyone can point me in the right direction, I'd really appreciate it!
