Thread: IntersectWith says lines don't intersect
    Angry IntersectWith says lines don't intersect
    Using the Extend command both sets of lines below will intersect each other. Using the line command and intersection snap for line selection, both line sets return a line from the apparent intersection. Using VBA IntersectWith the first set of lines fails, the second set of lines returns a point.
    The line points are determined mathmatecally identically, the only difference between the coordinates is the UCS used to perform the design. Why does it not work and produce the same results regardless of the UCS?
    Dim oPoint as variant
    opoint = oline1.IntersectWith(oline2, acExtendBoth)
    Data for the fail result:
    Line 1:
    156,278.737825336822,0
    156,245.665579823409,118.1451695696
    Line 2:
    23.0866842342004,277.987825336822,0
    156,244.915579823409,118.1451695696
    Data for the working result
    Line 1:
    15,139.75,-2.012174663178
    -103.1451695696,139.75,-35.0844201765914
    Line 2:
    15,271.9133157658,-2.012174663178
    -103.1451695696,139,-35.0844201765914
    2000-01
    Seattle WA USA
    5,859
    Default Re: IntersectWith says lines don't intersect
    I think that posting the drawing(s) itself might attract more help.
    R. Robert Bell
    Design Technology Manager
    Stantec
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Just a shot in the dark:
    Check elevation properties for both lines
    ~'J'~
    Finally got back to this project ... as it turns out, the lines being used to determine the intersection were pars of a solid that cannot be referenced.
    Once I drew lines about those edges of the solids necessary to determine intersections, it all worked ok.
    Lesson learned ... you can't reference something that isn't physically there with VBA.
  1. IntersectWith motod problem VBA
    By 4gokay372489 in forum VBA/COM Interop
    Last Post: 2013-02-06, 11:22 AM
  2. IntersectWith Problems
    By srperrier in forum Dot Net API
    Last Post: 2011-08-05, 08:07 PM
  3. Problems with IntersectWith
    By Lee Mac in forum AutoLISP
    Last Post: 2009-05-17, 11:20 PM
  4. Intersectwith issue
    By kerbocad in forum VBA/COM Interop
    Last Post: 2009-02-19, 03:27 PM
  5. IntersectWith Question
    By david.brissenden in forum VBA/COM Interop
    Last Post: 2008-10-13, 01:59 PM
