Thread: Section Planes and Layout Viewports
    2008-10
    London, UK
    103
    Default Section Planes and Layout Viewports
    Hi all.
    Ok, so I am having trouble getting a section view of my model into a viewport in my layout space.
    I can get a section plane, and use live section to get the view I want, that isn't a problem. I just can't get a seprate viewport to show this in my layout space. I already have a couple of viewports, showing various view of the model, but I want a couple of sections to show some other areas better.
    When I use the live section it effects all the other viewports as well.
    I think I might have to set up a named view with the section plane, but this seemed to mess up the other viewports as well when I created a viewport and used this new named view.
    I'm sure what I want to do is pretty straightforward, but I just can't work it out.
    Any tips or help would be much appreciated.
    Thanks
    Jon.
    NB, I am actually using vanilla autcoad and not mechanical for this.
    2008-10
    London, UK
    103
    Default Re: Section Planes and Layout Viewports
    Ok, so I have found the solview and soldraw commands, looks like that is what I need to use to do the sectio views I want.
    This must be basic stuff for autocad 3D, just never having any tuition I am having to work it all out for myself!
    Getting there though, slowly.
    2016-12
    Yes I'm wondering this too. I'd much rather live sections than have to cut 2D sections that don't update. Have you figured this out yet? Seems like a basic task after using Revit.
    Ronnie
    Active Member ervin_david's Avatar
    2004-07
    Southeastern USA
    98
    turn off clipping planes in model tab
    in layout tab, switch to model space in one of the viewports and select 3dclip and set the clipping planes. set the viewport scale. pan to center view, Lock the display of the viewport.
    set the clipping planes in each viewport
    the clipping planes will not change.
  1. Different Plotstyles for Different Viewports in Same Layout
    Last Post: 2010-06-09, 05:36 PM
  2. multiple viewports in layout for 3D or 2D
    By Richard.Kent in forum AutoCAD Tips & Tricks
    Last Post: 2009-05-15, 11:20 PM
  3. Replies: 3
    Last Post: 2008-01-17, 01:08 PM
  4. Cycle through nested viewports in a Layout
    By kb3cxe in forum AutoCAD General
    Last Post: 2005-12-16, 01:50 PM
  5. Named Viewports on Layout Tabs
    By Scott.Baumann in forum AutoCAD General
    Last Post: 2005-05-13, 02:51 PM
