Thread: Volume calculations in structural foundation schedule
    2004-05
    Reynolds, GA
    40
    Default Volume calculations in structural foundation schedule
    Has anyone else ran into the volume calculations being wrong in a structural foundation schedule? I have thickness,width,length volume cf field in a schedule and checked all instances. I rounded the length to the nearest inch but for some reason even the foundations that have not been rounded at all will come up with the wrong cf in the volume field. example 1´-0" thickness 2´0 width 9´-0 length volume shows up 17 cf. Even down here in south GA that should be 18 cf
    Anyone else seen this?
    James
    2004-06
    Memphis TN area
    7,048
    Default Re: Volume calculations in structural foundation schedule
    Any other foundations intersecting the one in question? Could it be at a corner and another footing is taking the volume at the corner area? I have several strip footings in a project, and I checked several of them and the volume reports correctly. On the ones where it seems the volume is not reporting correctly, Revit is actually subtracting the volume of an intersecting isolated footing, or the adjacent footing at a corner (which footing goes to the corner is determined by the wall join condition).
    Trust the volume computation. I'm 99.9% sure it is correct.
  1. 2012: structural foundation schedule area quantity
    By hkossila in forum Revit Architecture - General
    Last Post: 2013-09-12, 03:49 PM
  2. Composite volume versus grid surface volume calculations
    By rschaff in forum AutoCAD Civil 3D - Grading
    Last Post: 2011-10-04, 04:20 PM
  3. Volume calculations
    By Old Jim in forum Civil 3D - Civil Design Companion - General
    Last Post: 2005-11-09, 08:18 PM
  4. Structural Foundation Volume
    By Alvin_Alejandro in forum Revit Architecture - Families
    Last Post: 2005-04-29, 08:23 AM
  5. Structural framing vs Schedule (Volume report)
    By weeleng_02 in forum Revit Architecture - General
    Last Post: 2005-02-28, 01:08 PM
