j_menacker
AcadMEP 2011 WinXP64
When creating duct or pipe risers, it seems that AutoCAD MEP will only create the riser with rotation set to zero in the WCS. If a UCS is created aligned with a skewed wall, MEP will still create a vertical duct aligned with the original WCS.
I found that it is possible to create a skewed riser this way:
1. Make a skewed UCS current
2. Rotate the UCS 90 degrees on the X axis
3. Draw the riser in what is now a horizontal orientation.
Can anyone please shed light on a simpler way to create skewed risers?
Thank you,
Joe Menacker
I could not recreate your problem with a UCS rotated slightly on the Z axis to match an unsymmetrical wall.
However, try this to see if it works, type
Command: PLAN
Enter an option [Current ucs/Ucs/World] <Current>: <Enter>
This will align the WCS to the current UCS which will allow you to continue working in an "normal" drawing environment. Hope it helps.
