Thread: grey ribbon
    2010-07
    2
    Default grey ribbon
    sometimes, not all the time, when mtext command is used on one of my workstations the ribbon goes "grey". I've read in other discussion groups the fix is to reinstall the mnu file, which I've done - didn't work. Anyone else have this issue?
    2003-03
    Philadelphia, PA
    2,371
    Default Re: grey ribbon
    Do you have two CUIX files loaded at the same time that have a contextual ribbon tab that fires for the MTEXT or MTEDIT command? If you have both the out-of-the-box ACA.cuix and ACAD.cuix file loaded, you do. You may want to read more about this and potential solutions in this brief blog article.
    David Koch
    2010-07
    2
    Yes, it does. That has to be it. I'll try the recommendations in the blog article...Thank You!
    2009-11
    5,526
    Could you possibly be referring to the contextual ribbon panels?
    When you start the MTEXT command, once the cursor begins to blink in the text box, a new ribbon tab is visible (blue) called "Multiline Text".
    Computer Specs:
    Dell Precision 3620, Core i7-7700K 4.2GHz, 64GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
  1. Replies: 20
    Last Post: 2015-05-16, 12:14 AM
  2. Replies: 0
    Last Post: 2014-12-01, 03:30 AM
  3. Replies: 0
    Last Post: 2013-07-14, 08:22 PM
  4. Need to set everything in this dwg to Grey
    By dixie1222 in forum AutoCAD General
    Last Post: 2008-11-20, 09:05 AM
  5. UNDERLAY IN RED RATHER THAN GREY?
    By ykang in forum Revit Architecture - General
    Last Post: 2006-10-24, 03:59 PM
