interesting indeed. looks like an old version of Revit. Some is outdated, but principle is the same...
I was thinking the same thing....looks like Revit 3 or 4. Some is very outdated:
- We can not change a corner of two walls into a curved one (like the "fillet" command in Autocad).- We can not define a dormer window.
- We can not extrude a solid by linking the sides of the top and the bottom polygon ("blend" command) if the polygons are not of the same shape.
- We can import only .gif and .bmp images, which are view dependent and can be placed only in 2D views.
Each of these four 'limitation" points is no longer true.
I'd expect more from Harvard....
Aaron Rumple
Yale '86
