Results 1 to 7 of 7
Thread: Roof Rafter or Truss option
    2010-04
    13
    Default Roof Rafter or Truss option
    I'm creating a simple hip roof in Revit 2010, but my instance properties does not allow to choose between rafter or truss construction. Is there anything special the needs to be done for this property to show up in the construction parameters. The way I have created the roof is by using a 1'-6" offset of my exterior walls and then defining the slopes of each face. Any help is greatly appreciated, thanks
    2015-12
    Orlando, FL
    1,049
    Default Re: Roof Rafter or Truss option
    I have reproduced the steps that you have described, using 2010, and my "Rafter or Truss" parameter is available for change. It is difficult to tell what might be causing this without looking at the file.
    2010-04
    13
    Thanks for your response Alfredo, I've tried creating it again just by using the OTB generic roof types and still no parameter. Is there any chance you could list the steps your using so that I could compare? Again, thank you for your help in this matter.
    2015-12
    Orlando, FL
    1,049
    What I am doing is this: From a second floor plan (or site plan), Home > Roof > Roof by footprint > offset = 1'-6" > pick walls > (select edges, edges defines slope),(roof type is "Generic x mm" ) > Finish . Then, I select the roof, and the parameter is there, available for change.
    2010-04
    13
    I was able to find the truss/rafter option, I didn't realize that you need to pick the walls for that parameter to be available, (newbie mistake). The problem that I continue to have is where revit places the pitch point or base point of my truss from. Do you have any suggestions of what would best to solve this problem, if I move it down manually then the height I want for the top of my truss is incorrect.
    2015-12
    Orlando, FL
    1,049
    Check this other similar thread from the Autodesk forum, especially Jeff Hanson's reply; look at the image he posted about Roof conditions:
    http://forums.autodesk.com/t5/Autode...ht/true#M45663
    All AUGI, all the time DoTheBIM's Avatar
    2005-02
    Central PA, USA
    756
    I rarely pay attention to roof offsets or truss/rafter setting anymore. Simply make your roof outliine as you need and pitched as you need. Move the roof up or down in section or elevation to get it where you need. I only get into offsets if I have eaves that aren't all at the same elevation in one roof object.
  1. 2015: Get Roof Soffit To Have Same Rafter Cut As Roof?
    By jledgewood in forum Revit Architecture - General
    Last Post: 2014-07-16, 04:09 PM
  2. Choosing Rafter or Truss Construction
    By mrdavie in forum Revit Architecture - General
    Last Post: 2010-11-15, 09:37 PM
  3. Roof Rafter Cut weirdness
    By rtaube in forum Revit Architecture - General
    Last Post: 2010-06-07, 03:37 PM
  4. Roof/rafter constraints, someone have a method?
    By Kroke in forum Revit Architecture - General
    Last Post: 2007-03-26, 06:40 PM
  5. Roof: Rafter or Truss
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2003-09-30, 03:39 AM
