Thread: "Lock" a view?
    2002-06
    North Central CT
    1,108
    Default "Lock" a view?
    I think I already know the answer (NO!) but....
    Is there a way to lock down a 3D view and prevent someone from rotating or orbiting around in it? I've got a couple of 3D views set up - one with the systems and another with the systems and steel and I want to create some renderings of both and overlay them in Powerpoint and fade from one to the next. If I need to go back and redo the renderings I need the 3D views to be the same as before.
    Matt
    2005-08
    11,000 feet atop a chute
    1,001
    Default Re: "Lock" a view?
    Hey Matt,
    No on the lock.
    What you can do is right click on the View Cube and Set Current View as Home.
    This way you can click the house and your back to business.
    Also I would Bury the view in a "DO NOT TOUCH" Sub-discipline or something alone that line.
    2009-07
    KC
    338
    if you right click on the nav cube thingy you can get an option to "set current view as home". do that once you get it looking how you like, and then after that you can rotate all you want and click the house icon above the nav cube to return to that view (home).
    hth
    mike
    jrobker beat me to it...
    2002-06
    North Central CT
    1,108
    Quote Originally Posted by moliva View Post
    hth
    mike
    Hey, that'll work! Thanks!
    Matt
  1. Replies: 0
  2. "detail view" vs "floor plan" in callouts
    By shane.249457 in forum Revit Architecture - General
    Last Post: 2011-03-08, 09:29 PM
  3. Replies: 3
    Last Post: 2007-10-23, 09:06 PM
  4. "Lock" underlay view?
    By Nic M. in forum Revit Architecture - General
    Last Post: 2004-07-01, 09:00 AM
  5. View specific "lock" of elements
    By Nic M. in forum Revit Architecture - Wish List
    Last Post: 2003-10-08, 12:50 PM
