Thread: lighting fixture label,tag
    2006-04
    418
    Default lighting fixture label,tag
    i want to edit a canlight (and other lighting) families to include a label or tag that will show in my reflected ceiling plans and schedule accordingly....can't seem to import label into can fixture
    2015-12
    Orlando, FL
    1,049
    Default Re: lighting fixture label,tag
    Instead of editing your lighting fixtures components to add a tag, you can create a lighting fixture tag family. Start from a Generic tag template, set its category as "Lighting fixtures", add a label for "Mark Type", then load into project > Tag all > Lighting fixtures. Then all your lights will be tagged. See illustration.
    2006-01
    4,516
    Or if you want them to all be tagged automatically, make a Generic Annotation, put the label in it, nest it in to the Light families, and tie the parameter to a Type parameter in the light fixture.
    2006-04
    418
    i tried the "generic model element tag" and got this warning
    While loading family 'Generic Model Element Tag': Only the following kinds of families can be loaded into a 3d model family:
    - 3d model families
    - detail families
    i will try other annotations
    2006-01
    4,516
    A Generic Annotation is not a Generic Model Tag.... Use a Generic Annotation.
  1. 2012: Lighting Fixture Tag
    By rdooley944157 in forum Revit MEP - General
    Last Post: 2012-08-07, 06:21 PM
  2. Lighting Fixture
    By daryl.marshall in forum Revit MEP - Families
    Last Post: 2011-05-16, 07:20 AM
  3. Lighting Fixture Tag
    By Beancud in forum Revit MEP - Families
    Last Post: 2009-02-12, 02:20 PM
  4. Lighting Fixture
    By MNsnowtaTy in forum Revit MEP - General
    Last Post: 2008-04-17, 08:50 PM
  5. Rotating Lighting Fixture
    By Jit in forum Revit Architecture - General
    Last Post: 2004-03-09, 10:04 PM
