Results 1 to 1 of 1
Thread: Reference planes work planes and levels best practice
    2009-07
    Milwaukee Wisconsin
    30
    Question Reference planes work planes and levels best practice
    New to Revit Structure no analytical need now Just 3d coordination efforts
    I do not want to adjust instance parameters for each piece of beam and bracing I add
    How can I best leverage work planes and references to this end?
    My take is reference levels are dependent on work planes
    Work planes are constrained to model levels
    so...
    level-2 = 20'
    I have columns, beams and bracing to place
    We are doing secondary structure infill , so only linked revit structure model for what to avoid
    I need to place columns at places other than levels created for model IE: top of retaining wall top of non piled footing Do I create level ref plane or use a work plane based on?
    top of steel for beams is 3/16" below that level and offset up with vertical spacing of 6'-8" each (all horiz and perp to each other)
    i would like for this increment to be constrained somehow
    Bracing (kickers) beam to col
    I am guessing that is mostly an instance property? streamlined process tips and tricks would be nice.
    I posted here as I could see where this would apply to architectural when laying out preliminary design concepts
    thanks in advance
    REE
  1. Replies: 1
    Last Post: 2015-03-01, 07:14 PM
  2. Work Planes vs. Levels for Structural Components
    By zanno in forum Revit Structure - General
    Last Post: 2012-02-13, 08:46 PM
  3. Difference between Reference lines and Reference planes
    By adnama in forum Revit Architecture - General
    Last Post: 2009-10-28, 04:39 PM
  4. Replies: 1
    Last Post: 2007-08-04, 08:05 PM
  5. work planes cant be ref planes??
    By Martin P in forum Revit Architecture - General
    Last Post: 2003-06-10, 11:25 AM
