Thread: Block defination missing
    2010-08
    Default Block defination missing
    HI,
    I have been using autocad for quite sometime but there is this problem i just cannot find solution to.
    When we create a block in a drawing, say we select three objects and combine them in a block format. In my autocad I cannot save it, the moment i hit save, all goes back to normal and those objects do not combine as block.
    ps: i do enter the block name before hitting save.
    please help me with this. My drawing is so heavy now because of so many individual lines.
    0,0,0 The Origin
    8,570
    Default Re: Block defination missing
    If you're using the BLOCK command, you need to check the "convert to block" radio button before clicking "OK".
  1. Tool Palette Block Icons Missing
    By certsenian in forum AutoCAD Customization
    Last Post: 2017-05-18, 10:36 PM
  2. 2013: Insert block dialog missing - shows at command line instead
    By alpevarnek in forum AutoCAD General
    Last Post: 2012-12-18, 06:59 PM
  3. Replies: 4
    Last Post: 2012-09-06, 03:57 PM
  4. Add distance dialog box in block editor missing. Help Please!
    By jmcbride.161140 in forum AutoCAD General
    Last Post: 2008-05-20, 01:51 PM
  5. "Reset Block" is missing from Right Click menu
    By Rico in forum AutoCAD General
    Last Post: 2008-01-15, 04:24 PM
