Thread: Using lisp to Automatically export to shapefile
    2007-08
    12
    Question Using lisp to Automatically export to shapefile
    Hi I am not completly new to programming but is there a way to use lisp or even .net to
    run a script or routine that would export a number of shapefiles from a dwg with object or link data?
    Thanks
    Earth
    9,819
    Default Re: Using lisp to Automatically export to shapefile
    Have you tried scripting the .-mapexport command?
    R.K. McSwain | CAD Panacea |
    2009-11
    5,726
    RK gave you a great solution for exporting to a shape file.
    To help you will developing code to add the Object Data (OD) to the objects prior to export (Acad Map or not), this may help:
    I've compiled all of the documentation I've been able to find on this topic here:
    http://forums.augi.com/showthread.php?t=122603
    You can use the PDF link I reference to see all of the functions you would need to get, put, manipulate Object Data (OD), etc.
    I understand you're new to programming, so this documentation may seem a bit overwhelming.
    Hope this helps!
    Computer Specs:
  1. 2013 Help with Shapefile export
    By dlh340951 in forum AutoCAD Map 3D - General
    Last Post: 2013-02-13, 12:20 PM
  2. Loss of Shapefile Export
    By Matt_Drainage in forum AutoCAD Civil 3D - General
    Last Post: 2009-02-04, 11:29 PM
  3. Export Revit to AutoCad (automatically naming layout 1)
    By Baldwin_4-6-0 in forum Revit Architecture - General
    Last Post: 2007-01-01, 06:14 PM
  4. Automatically Export Parameters
    Last Post: 2006-04-06, 05:14 PM
  5. Export Flood Trace to shapefile
    By kevin.bell81772 in forum AutoCAD Map 3D - General
    Last Post: 2005-08-19, 03:13 PM
