Thread: 64x vs 32x
    2002-01
    Richmond, CA Lifer
    72
    Default 64x vs 32x
    I am buying a 64-bit mobile workstation. Can I run 32-bit AutoCAD versions on it? Can I load 64-bit and 32-bit versions on the same workstation and can the AutoCAD files run on either software .
    Earth
    9,805
    Default Re: 64x vs 32x
    Generally speaking --- Yes, yes, and yes.
    You may run into problems installing some older versions on Win7x64, for example Land Desktop 2008 (32-bit) will not install, but Land Desktop 2009 (32-bit) will install OK. There are workarounds when the installer fails though - search around.
    R.K. McSwain | CAD Panacea |
