Is there any way to make a non-planar slice through a solid? I need it to rotate through a 5 degree twist as it slices. I am trying to cut a shape much like a watch gear, toothed on one side. There are 36 teeth on one end of a cylindrical sleeve that is closed on the other end. The top of each tooth would be separated by 10 degrees, with the bottom of the cut 5 degrees from each.
Failing to produce a solid that I can subtract from the tube by other means, I am hoping that the attached example will illustrate my problem. Some attempts are on layers that are turned off. For instance, I tried taking a 10 degree portion of the sleeve in the GearCut layer and then using two of the surfaces from the 2D layer to slice it. Any ideas?
