Results 1 to 10 of 16
Thread: Autocad Drawing Appears Faded
    2010-08
    18
    Question Autocad Drawing Appears Faded
    Before I get some of the standard suggestions here is what I have verified:
    All of the layers in my drawing are unlocked.
    The Layer Isolation command is not currently being used.
    I have a small food service equipment xref in the drawing but the rest of the drawing is not x-ref'd.
    Transparency is set at 0.
    My drawing plots off normally but EVERYTHING (including xref and line work within drawing) appears faded on the screen.
    I have closed and reopened the drawing and it still appears faded like when you isolate your layers.
    The only cause I can think of is that I was editing a xref and closed the drawing before i closed out of the xref (food service equipment).
    Any suggestions would be appreciated. My drawiing is editable but just looking at it in this faded state is annoying.
    2009-11
    5,538
    Default Re: Autocad Drawing Appears Faded
    Welcome to the forums!
    For clarification, are you having this issue in modelspace or paperspace (layout)?
    If only in paperspace, have you considered Viewport Overrides?
    Hope this helps!
    Computer Specs:
    Dell Precision 3630, Core i9-9900K 5.0GHz, 128GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
    Cairo - no, not Illinois
    4,850
    closed and reopened drawing -- a good first step towards fixing the problem.
    Is the fading issue resolved if you close and reopen Acad? If that doesn't resolve it, try restarting the computer.
    It sounds like the display driver is misbehaving -- is your graphics adaptor/driver on the autodesk supported list?
    Earth
    9,788
    Quote Originally Posted by tera.a.richards View Post
    Just for grins....have you tried the ._Refclose command?
    R.K. McSwain | CAD Panacea |
    2010-08
    18
    Unhappy Re: Autocad Drawing Appears Faded
    rkmcswain - tried the ref close command and "command not allowed unless a reference is checked out with REFEDIT command".
    -Thanks anyways!
    cadtag - just rebooted my whole computer hoping that would solve it but didn't. I will check to see if my driver is on the list. Last time I checked I dont think it was but I thought graphic cards were still being added.
    RenderMan- the drawing appears faded in both model space and in viewports. I didn't add this before but it seems to only be a problem for this particular drawing. Any other drawing I open appears normal.
    I have been working on this drawing for some time (3-4 months) and although Ive had a few issues its generally been a smooth go for this drawing. I have no idea what I could have done, but anything is possible.
    I know Im new to the threads her although Im not completely tech illiterate I dont know how to find my thread after I have posted it. I have bookmarked it for now but Im sure there is an easier way. any help?
    Earth
    9,788
    Create a bookmark pointed to: http://forums.augi.com/usercp.php?
    This page will list all of your subscribed threads (among other things) - and any subscribed thread with a new post will show up, along with a link to the oldest post in the thread that you have not seen.
    Earth
    9,788
    ....tried the ref close command and "command not allowed unless a reference is checked out with REFEDIT command".
    Ok, have you tried adjusting XFADECTL? If not, set it to 1 and see if there is any difference...
    2010-08
    18
    Tried this command. Originally it was at 50 so I switched it to 1 and regenerated it. No difference unfortunately.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,516
    Have you run Audit or Recover on the drawing? Can you insert this drawing into a new drawing and it show differently?
    2010-08
    18
    I did in fact do a a audit on the drawing thinking it was some random error and got nothing. copying and pasting sounds like a wonderful idea if I knew my system wouldn't crash as this drawing is pretty elaborate. I will try pasting a portion into a new drawing and see how that goes.
  1. 2015: "Appears in Drawing List" parameter added to a drawing index schedule
    By ron.randell in forum Revit Architecture - General
    Last Post: 2015-06-25, 09:01 PM
  2. Autocad LT 2010 faded reference files?
    By verna in forum AutoCAD General
    Last Post: 2010-08-04, 06:52 AM
  3. 2011: Blurred and Faded Drawing.
    By dosx in forum AutoCAD General
    Last Post: 2010-07-10, 03:17 PM
  4. XClip appears to slow down drawing file
    By jsraider in forum AutoCAD General
    Last Post: 2007-04-10, 12:39 AM
  5. Replies: 2
    Last Post: 2005-08-15, 03:50 PM
