Results 1 to 9 of 9
Thread: HOT! Keys
    2008-09
    Default HOT! Keys
    I am a shortcut freak, if I can cut down the number of key strokes or amount I have to move and click my mouse I will. You can create all kinds of shortcuts using SHIFT, CTRL and the ALT keys by going thru CUI. But I found this cumbersome trying to get all the keys pressed at the same time, etc. Then I was shown the acad.pgp file and I could create all kinds of hot keys on the left side of my keyboard (I am right-handed). This is a completely editable text file were one can create 1, 2, 3 (or more) letter/number combination hot keys.
    It can be accessed from the Ribbon (I am using AutoCAD Architecture 2011, but it's also on 2010 and existed back to Architectural Desktop 2004 when I first started using it. A pgp file also exists for AutoCAD LT and AutoCAD).
    Go to the Mangage tab, Customize panel then to "Edit PGP". Work out what the command is, figure out a couple of hot keys and add it to the list along with the command line command in the same format at the rest.
    There is a boatload of existing hotkeys already and they are in alphabetical order, so there may be one for you command already.
    Save the file, go back to your drawing, re-initalize (REINIT on the command line and check the PGP File box and then OK) or close and re-open CAD and you're ready to use your new shortcut.
    If a command line command exists, you can make a shortcut.
    And if you upgrade your software, the pgp file does migrate with the rest of your settings!
    Mike V.
    Custom Mill Shop Drawings In-charge
    CAD Manager
    2000-01
    Seattle WA USA
    5,859
    Default Re: HOT! Keys
    And then you'll wish that you could create shortcuts that not only start a command but also execute an option, such as ZE=Zoom,Extents.
    Which means that you will take the next step in AutoCAD customization addiction by discovering Visual LISP:
    (defun C:ZE () (command "._Zoom" "_extents") (princ))
    Enjoy, my padawan.
    R. Robert Bell
    Design Technology Manager
    Stantec
    Earth
    9,809
    One more note...
    Shortcuts defined with lisp overwrite those defined in the PGP file.
    R.K. McSwain | CAD Panacea |
    2009-11
    5,723
    Quote Originally Posted by RobertB View Post
    Enjoy, my padawan.
    Forgive me, my Master, but is that code not Auto LISP...?
    I believe you meant this to be your Visual LISP equivalent:
    (defun c:ZE ()
      (vl-load-com)
      (vla-zoomextents
        (cond
          (*acadDoc*)
          ((setq *acadDoc* (vlax-get-acad-object)))))
      (princ)) ;_end defun
    Computer Specs:
    2000-01
    Seattle WA USA
    5,859
    Talking Re: HOT! Keys
    Quote Originally Posted by RenderMan View Post
    Ah, my young padawan, let me show the ways of the Force...
    Visual LISP is the environment for developing and executing AutoLISP code. AutoLISP is the language. The Visual LISP environment provides access to ActiveX (in addition to the VLIDE and compiling). The language is still AutoLISP but Visual LISP extends AutoLISP. The environment in which the code works, be it my example or yours, is Visual LISP. (See the AutoLISP Developer's Guide, Using the Visual LISP Environment, Getting Started, Loading and Running AutoLISP Programs, Using Extended AutoLISP Functions. Note how the ActiveX support is spoken of as extending AutoLISP.)
    I've always preferred to think of Visual LISP as AutoLISP v2.0. It's similar to the move from BASIC to Visual Basic. If I developed a small bit of code in VB that was exactly like code from BASIC would we call that code BASIC when it was developed in the Visual Basic environment? Probably not. We would say, "Look at this VB sample."
    So at this point you say, "But master, the code is AutoLISP!" To which I say, "Ah, but my young padawan, the Force, er, Visual LISP, surrounds and affects all life, er, AutoLISP code."
    R. Robert Bell
    Stantec
    Earth
    9,809
    Robert, for some reason I want to call you Yoda now...
    2009-11
    5,723
    (If only for the sake of perpetuating the Star Wars references...)
    "Master, I've disappointed you. I have not been very appreciative of your training... I have been arrogant and I apologize... I've just been so frustrated with the Council." ―Anakin to Obi-Wan
    Computer Specs:
    2000-01
    Seattle WA USA
    5,859
    Hideous like Yoda am I.
    So I finally got around to reading Episode 1 and Jar-Jar was just as irritating in the book as the movie. <sigh>
    R. Robert Bell
    Stantec
    2006-11
    2
    Just read your thread.
    Loved the Star Wars reference. Made me smile after a very long day
    (besides the useful info)
  1. Product Keys?
    By Chad Smith in forum Revit - Platform
    Last Post: 2009-07-27, 02:29 PM
  2. Hot Keys
    By bparrell in forum NavisWorks - General
    Last Post: 2009-03-11, 01:11 AM
  3. Quick Keys
    By greg.gebert978266 in forum Revit Architecture - General
    Last Post: 2008-07-31, 05:27 PM
  4. Is there a way to change your quick keys, or short cut keys?
    By smooth shoes in forum AutoCAD General
    Last Post: 2006-11-16, 12:22 AM
  5. Help... Hot Keys???
    By Girlsrfast2 in forum Revit Architecture - General
    Last Post: 2006-05-24, 05:52 PM
