Hello:
Is there any automated way to break a multiple tab drawing into single tab drawings and also have the entities in model space that are not displayed in the paperspace viewports deleted?
Hello:
Good question Steve, I've just spent the last six hours doing just the same.
If youdon't get an answer be sure to add this "wish" to the wish list.
Wayne
File > Export Layout to Model
-or-
Right click on the active layout > Export Layout to Model
-or-
EXPORTLAYOUT
You might try Jimmy Bergmark's layoutstodwgs.lsp. I've used it for a few years now to break out a set of plan sheets.
thanks Opie:
that's half the problem licked. I think I've found other half. I just don't know how to run the program. any ideas?
Here's a link:
http://www.cadtutor.net/forum/showth...de-paper-space
I'm not sure this will solve your problem, but you might try the EXPORTLAYOUT command.
Hello:
No problem moving the layout tabs to drawings.....
now what do you do with the #$&% scale??????
linetype scale was 1 now it is 0.0312. HELP
NEVER MIND I FOUND A WAY TO MAKE IT WORK.......
HAD TO SCALE IT AND USE PRE PAPERSPACE TEXT SETTINGS...
THANKS ANYWAY
Melanie Stone
@MistresDorkness
Technical Editornot all those who wander are lost
